Question about Archos 504 500870 Digital Media Player
Archos 504 hard drive upgrade
I have an Archos 504 with firmware 1.6.53. Is there a way to upgrade the hard drive? Thanks.
Judy
  • go to archos.com
  • go to support and account near top of your screen and go to downloads
  • the archos website should tell you what to do next
Posted on Oct 20, 2009
6ya staff
SOURCE:
How do i update my Archos 504?
How to install firmware ..?(update)
Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
  • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
  • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
  • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
Step 5. Disconnect the Device
Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
Step 6. On your ARCHOS device, click on "Update Firmware"
Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
Dec 31, 2010 | Archos 504 500870 Digital Media Player
ARCHOS 504 160 GB
As long as you replace the hard drive with the same exact one, it should be possible. You can contact the manufacturer with the below options and they can assist you in getting a new drive.
Main support number (877) 300-8879
Email support tech-support.eu@archos.com
Let me know if you need any more help and good luck to you
Mar 29, 2008 | Archos 504 500870 Digital Media Player
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
I want to have hebrew in my archos 504
Update your device at Archos official site/support/downloads/firmware and select your Archos model.
Dec 18, 2010 | Archos 504 500870 Digital Media Player
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
Nov 27, 2010 | Archos 504 500870 Digital Media Player
Arch 504 i change hard drive
You canĀ“t swap the internal hard drive if your current firmware is superior to v1.4.0, because system locks it during bootloading (system reads hard drive ID).
May 11, 2010 | Archos 504 500870 Digital Media Player
Where is my serial number for my archos 504 , i
remove the battery and read in the sticker of the exposed 2.5´´hard drive.The serial number is indicated with SN or S/N plus several numbers.
Dec 09, 2009 | Archos 504 500870 Digital Media Player
My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
Dec 23, 2008 | Archos 504 500870 Digital Media Player
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Recovery code 4 on archos 504
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Nov 01, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
608 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
