Vizio L37 Television Logo
Posted on Dec 23, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RGB Hi I was watching my tv and I accidently pushed the RGB button.  Then it shut itself off and when I turn it on it shows "No Signal".  How can I right this problem?? David
A
Anonymous
47inch tv. Turn on manually with on/off sensor button. Once it turns on (the screen is blue and says no signal) - press the "source" sensor button three times in a row. The input menu magically appears. Press the source button as many times as it takes to get to the input which brings back the tv. In my case, TV.
Anonymous
Level 2:
  • Expert 137 Answers
  • Posted on Dec 24, 2007
Anonymous
Expert
Level 2:
Answers
137
Questions
Helped
36389
Points
214
Press input until tv apears again. Or go into menu , setup Video input and select av or tv what ever you use.
Lost signal
Have you tried to push the tv input button? Sometimes when a button is buy accident it changes the input on the tv. Hope this works, let me know.
Good luck, Toni
2helpful
Vizio light is on on the front of tv, but when you turn it on it says no signal and turns off. VX37L
Your TV may be in RGB mode. Immediately after turning your TV on, press the TV button on the 'input' section of the remote. Hopefully that works for you. Your TV is designed to turn itself of in RGB (monitor) mode if no signal is present.
2helpful
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
2answers
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Blue screen No signal
Hi peed941,
Try pushing the input button on the remote, it sounds like you have accidently changed the input to anntenna.
Let me know if this helps and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
2helpful
4answers
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
48helpful
4answers
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
310helpful
25answers
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Thanks
9helpful
6answers
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
