SOURCE: hi! no sound from toshiba tecra notebook
Check the volume knob usually along the side or front first.
If you're sure its turned up, then i would install sound drivers from http://pcsupport.toshiba.com and let us know if that doesn't fix it.
Include what model tecra if you have further questions please.
Don
SOURCE: Drivers for Toshiba Tecra 8100
Arifin,
Gud Luck
Iqbal
SOURCE: FN key not working on Toshiba Tecra A2
You can enable/Disable Fn key in System Setup.
to access system setup press F2 when you see the Toshiba logo
SOURCE: toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
