That's covered on pages 35 & 36 of the
owner's manual here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your
GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your
GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug. *
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see
here.
My spacemaker Microwave JVM1650 is sparking in the cavity where the light is above the ACTUAL MICROWAVE CAVITY. tHERE IS AQ ROUND METAL PIECE THAT IS SCREWED DOWN WITH 2 WIRES COMING INTO IT. WHEN I UNSCREW IT THERE IS A LONG PLASTIC/GLASS PEICE HANGIND DOWN. i THINK THIS IS WHATS SPARLING BUT CANNOT TELL BECAUSE i CAN'T SEE WHAT WELSE IS UNDER THE METAL PLATE THAT THE DEVISE IS SCREWED TO. WHAT IS THIS PEIVED AND IS IT SOMETHNG I CAN REPLACE? THANKS.
model xnj4670827
replaced bulb blows as soon as turned on
