I have connected my advent roma to my hdtv via hdmi and now all i get is a grey fuzzy screen. I have had picture before but not anymore.
If you can give me some more detail, I might be able to help. Are you trying to connect your computer to your TV? If that is the case, most graphic cards can be set for dual output, but in most cases this has to be enabled through the software that came with your graphics card or by going to the properties screen on your computer monitor. There are several ways to do it. Hope this helps
You have to make sure the frequency and resolution are set correctly...ex 60, 70hz, and xxxx X xxxx. If these doesn't match the specs of the tv no picture is displayed. swtich your display options the show both screens and begin changing them to find one that works.....you prolly changed the resolution on your desktop between the last time you had it working and now. and although your Dell and TV should both have an auto adjust feature, they dont always work.
Good Luck and pls rate this post as fixya
Hi steve,
it's an advent roma laptop connecting to an LG 50". Thanks for your help.
It says screen resolution on tv is 1360x768 at the moment. Trouble i always have problems with my tv, quite difficult to use system on it.
