Dell 1720dn Laser Printer Logo
Anonymous Posted on Oct 05, 2009
Dell 1720 laserjet printer
Where can i find the counter to see how many pages have been printed
Anonymous
Level 2:
Scholar:
  • Expert 81 Answers
  • Posted on Oct 05, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
81
Questions
0
Helped
53832
Points
260
After you have replaced the imaging drum press and hold the cancel button until all lights flash in sequence.
Any questions leave a comment
How do i print a confige page on a dell 1720
Turn off the printer
Open the front cover
Press and hold the Continue button as you turn on the printer - all the lights will cycle
Release Continue button and close the front cover
Press the Continue button until the lights cycle and the configuration page will print
1helpful
How can i rest photoconduct kit is finished life time?
To resert drum counter, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Where can i find a installation disk for the dell 1720 laserjet printer tryed to download them but no luck
click here
click on above link then select your operating system and download driver then install.
Let me know if you need more assistance.
Thanks.
Dell 1720 laserjet printr
There should have been instructions with the replacment drum unit, for resetting the drum counter.
If not check your manual, or if you can't find it, download ot from Dell website
2answers
How do I find the page count on my Dell 1720 printer?
  1. Turn off the printer.
  2. Open the front cover.
  3. Press and hold the Continue button continue_button_0.jpg as you turn on the printer.
    All the lights cycle.
  4. Release the Continue button continue_button_0.jpg.
  5. Close the front cover.
    The light sequence representing the Home menu is displayed.
  6. Press the Continue button continue_button_0.jpg until all the lights cycle.
    The Printer Settings Configuration sheet prints.
Dell 1720 printer prints junk first page with only ?Z@ troofpaN.
This is a issue with the printer drive that windows is holding, not the printer. To Un-install your printer drive the correct way, goto add/remove programs, and un-install the printer there, then open up your printer control panel and right click where there is no printer. In the right click menu click server properties, then click the drivers tab, then remove the 1720/1720dn drivers there. A system restart will be necessary in most cases before it will let you remove the drivers(the Microsoft print spooler is to blame here for that). If this still doesn't work for you, then install a hp laserjet 4 driver and see if it does the same thing. if not, then it is something with the driver/spooler, if so, then it is the MCU of the printer, and you might want to look at buying a new printer.
1helpful
Dell 1720 flashinf replace drum- error.
I believe this message is occur because the laser printer drum needs to be replaced, not the toner cartridge.
These are two different things. The part is a DELL 310-8710 Drum Unit. Just google DELL 1720N drum and you should be able to find one.
82helpful
3answers
The second link was the helpful information. Also, to cut through all of that --
If you need to reset the counter:
1. Remove drum kit with toner
2. Make sure all print jobs are flushed otherwise whatever has been sent and not printed will come spewing out.
3. Hold down CANCEL Button until all lights flash through.
4. Slide the drum kit and toner properly into the Printer.
done.
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
