You posted this in regards to a Toshiba 42RV530U."
"I am expriencing "blinking three times, stopping, then blinking 3
times again" then green light comes on and I get sound no picture.
Can anyone help?
I had a similar problem to this yesterday. Tv is same Toshiba model as you mentioned about 4 months old. In my case, after the TV working perfectly following installation, the standby LED on the front (the one that is red on standby and green when on) went to a flashing orange (after switching on from standby) and the picture disappeared although the sound remained OK. I was unable to get any response from the setup or menu on the remote, otherwise I would have tried resetting the TV. Regardless of how much switching off/on (including disconnecting the powerlead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped. I looked up Toshiba's web site and under support they basically suggest switching off the TV and restarting using the onset buttons (not the remote) and pressing the menu button (again the one on the set (not the remote) and if you could get the menu box to appear then reset to default settings. I tried this but the results were the same. I therefore thought the TV was defective. However, after much frustration I did the following (I think): 1) Disconnect everything from the TV 2) Powered up from the mains switch whilst keeping BOTH the startup and menu buttons on the side of the TV pressed down. The result in my case was that the standby led and one of the two beside it flashed green simultaneously. However, when the buttons were released, the TV started up the same (flashing LED orange and sound no picture). 3) Pretty well defeated at this point, after doing the procedure at (2) several times with the same results, I somehow thought of pressing the standby button on the remote either whilst the two buttons on the set were depressed or just after they were released. I am afraid I cannot remember which and cannot replicate the problem as I don't know what caused it in the first place. 4) The TV then started normally ( no reception as I had not aerial connected, etc.,) but I was able to gain access to the screen menu/setup buttons via the remote which were in French rather than English. However, after reconnecting everyrthing the TV has worked fine (obviously after resetting the language via the menu). I am sorry I cannot be more precise but I hope this might be of help to someone with a similar problem.
I had the same problem until one day the yellow would blink three times, then three times again, then three times again... The TV would neither turn on or off.
Call the warranty number ASAP before your year expires and don't accept any "We never heard of that's." I have to schedule service tomorrow.
Regardless of how much switching off/on (including disconnecting the power lead and leaving for few minutes), disconnecting all peripherals, etc., nothing helped.
I have a similar problem. The picture went orange and green and would blink in and out and the sound stopped. Was unable to get the menu to work etc.
I unpluged the tv from the wall for about an hour, plugged it back in and it seemed to RESET Itself. I had read somewhere to RESET the TV you have to unplug it for at least 5-10 minutes.
It WORKED for me?
Hope it is not a short fix? Super Bowl is this Weekend?
Good Luck
The 42RV530U is known to develop problems in both the power board and the main board.
You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
It's a toshiba 32sl415u
