To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
How to turn off decimals in casio fx-300ms?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2] [=]. This will return the calculator to the following settings: Calculation mode COMP Angle unit Deg Exponential display format Norm 1 Fraction display format a b/c Decimal point character Dot Percentage Calculations
