fill bar oil allow for small amount of expansion from heat of bar and chain, but to get hot the chain must spin, and when the chain spins oil is used, just dont let it run out.
If the circuit breaker trips there are three possible reasons 1. the motor is being overloaded - clean underneath ( as recommended above); or if the grass is too wet or too long or both you may need to handcut; or the motor bearings need lubricating (same problem as me-how?) 2. There is an electrical fault - check the plug and cord (as above) or get an electrician to check the motor and connections; or the carbon brushes to the motor need replacing 3. You have a faulty circuit breaker! - borrow and test with a replacement
it should be held on by a long bolt & take the bolt out & got to any small engine store & buy another one or maybe a welder can weld it back on either way
