The wires are color coded, there should be a sub base, yellow, to yellow, white to white, black to black, green to green, and red to red
Melvin
St Louis
Typical wiring for thermostats: white to W, red to R, green to G, yellow to Y. If it is a heat pump, orange to O/B. blue to C. However, not all stats have a common.
1. Remove the packing material from the thermostat. Gently
pull the cover straight off the base. Forcing or prying on
the thermostat will cause damage to the unit
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6488.pdf
This is the manual for your unit.
