You may have to try using it in the safe mode. Check whether the same happens in the safe mode.
You can go into safe mode by pressing F8 as soon as the computer turns on.
If the system is good then probably you need to run a virus scan and check for viruses.
If any then it should be removed. It could be a spamware as well which cannot be detected by the virus scan.
Uninstall any malicious progams running in the system by going into control panel-> add or remove progams
Kindly comment after performing the same. If these does not help then I can help you with a complete reinstall of the OS (but please do back up all data you need)
Make sure you run antivirus scan. Do you see any error message. Let me know
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
if your installation disk is only a service pack 1 or 2 you might need to create an xp sp3 disk
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
hope this helps
