Apple iPod shuffle MP3 Player Logo
Posted on Dec 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ipod nano problems
When i plugged my ipod nano the computer reported that it was "corrupted" ... when i disconnected it my ipod would not turn on?... please help.. thx from texas!!!
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on Dec 21, 2007
Anonymous
Expert
Level 2:
Answers
59
Questions
5
Helped
21443
Points
101
  1. Try reseting the ipod:
http://docs.info.apple.com/article.html?artnum=61705
2. if that doesn't work use a program like copypod to transfer all your ipods files to your hard drive, then do a Factory Reset of your ipod
This will delete all your ipod files, back them up first with a program like copypod.
http://docs.info.apple.com/article.html?artnum=60983
2answers
Ipod 4G nano shows 0 songs when disconnected, but shows all data when connected t iTunes. Please help.
If you have all the music from the Ipod on your computer, I recommend you do a factory reset of the Nano. You could have a corrupted audio file that is messing everything up or your hard drive could be failing.
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
1helpful
Ipod nano 8gb shuts off after disconnected from computer
Your battery is on the fritz replace it with a fully charged one.
1helpful
I pod is frozen in Synchronizing plugged in and out and back into
Have you already attempted to reset the iPod?
If not you will want to attempt that as your first step towards resolving this issue.
To do so you will need to simply press and hold both the center and menu buttons for at least ten seconds or until the apple icon appears on the screen.
If this does not resolve your issue please do let me know.
Also in the future if the iPod seems to be frozen on the do not disconnect screen, shut down the computer and reset the iPod before disconnecting it. Improper disconnection can cause hardware corruption.
Screen on iPod Nano went blank (white)
press the play and pause button then on the bottom of the ipod theres a orange swich and make it turn orange...
Ipod nano
try deleteing everything on it before you plug it in, it could just mean there is a corrupt file on your ipod that the computer cant read.
Ipod corrupted
Reset, Retry, Restart, Reinstall, Restore Remember these five basic suggestions if you have a problem with your iPod nano. If one of the following doesn’t help, read on for solutions to specific problems. â Reset your iPod nano. See “General Suggestions,” below. â Retry with a different USB port if you cannot see iPod nano in iTunes. â Restart your computer and make sure you have the latest software updates installed. â Reinstall iPod and iTunes software from the latest versions on the web. â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
2answers
IPod 3rd G Nano syncing problem
maybe holding resetting the ipod might help by holding the middle and menu key???
2answers
Ipod nano 2gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
2answers
Ipod corrupted
You'll need to format your iPod.
There is 2 way's i know of you do this first one is to go to iTunes when your iPod is plugged in, now click on your iPod then click on "Restore" this will restore it to previours setting also should restore the corrupted it spoke of when you tryed turning it on.
If you've tryed formatting it through iTunes but was unsuccessful, try through my computer. Follow these steps below:
First click on "Start" - now click on "My Computer", now look for your iPod usually named "Removable Disk", once you've found it, right-click on it then click "Format", once format is complete, unplug your iPod then try it now.
Good luck. Hope my solution was helpful. Further problems leave a comment on here and i'll get back to you.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
