Dewalt 7.2-18.0 Volt One Hour Charger Logo
Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
Anonymous
Level 3:
  • Master 2,176 Answers
  • Posted on Oct 03, 2009
Anonymous
Master
Level 3:
Answers
2176
Questions
6
Helped
1310480
Points
5445
It doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Hello! I have a M51 Invacare Pronto that is not working. When I turn it on, the service light flashes eight times, one red battery light flashes as well, but nothing happens when I move the joystick.
If it flashes 7 green and one red for the 8 total then it's a joystick error. If it's 8 green and one red then it is a control/brain error code. Measure voltage on batteries when turn chair on. Both batteries need to stay above 11.5 volts each.
1helpful
Why does the battery flash from red to green while charging?
If it changes from red to green and stays green while being charged, it is just a sign that it is being charged and there is nothing wrong.
If it flashes back and forth between red and green while charging, there might be something wrong with your charger's connection.
2answers
What does it mean when my worx battery charger has a solid red light.
according to manualslib type site for the wg540, solid red means charging for the wa3840 and wa3838. After 30 minutes if battery has not reached 10 volts (of 18), the red will begin flashing meaning defective.
Just green? Ready to go. Green flashing? Overheat.
Tangent; sometimes a discharged battery needs a little coaxing - have to get a little voltage into the battery for charger to try to charge. Different company, electric drill. I plead ignorance if this applies for the 3840 since they mention the half an hour time.
Thanks for the help. It looks like the battiers have fully charged because the small green light on the charger is steady green and that means the batterys are charged. I put a volt meter on the batterys...
Phil after a full charge you should be reading more than 24.8 volts on the batteries I'm still leaning toward replacing the batteries of course thats not cheap but if you can locate 2 batteries from a provider that will let you try them on the scooter to see if that fixes the flashes you are getting I don't have too many more ideas to give you sorry
3helpful
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
5helpful
2answers
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
5helpful
2answers
Yellow & Green lights stay on,battery will not charge
I hooked a 12 volt car battery charger to the battery for about two min. Then I put it in it's own charger,the yellow & green lights came on for about 5 sec. then the red light came on . About 30 min. later the green light came on and the battery is fine.
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
