I have Windows 7 64-bit and couldn't install TotalMedia 3.5
It would only get as far as Select Video Device, and give 2 options:
> WinFast DTV Dongle Gold BDA Filter
> FM/DAB Dongle
I downloaded a driver (AF9015 BDA Driver - 9.6.3.1) from http://www.unisupport.net/
Select Video Device then gave these 2 options:
> AF9015 BDA Driver
> FM/DAB Dongle
The first one did the trick.
(The second one was possibly there because I have a Kaiser Baas USB FM radio.)
there is no transmission on FM because CB is at 26 to 27Mhz on the AM Band and as with your car radio FM starts around 88Mhz. the other reason is tha one one modulates amplatude(AM) slightly to cary the signal, FM modulates the frequincy slightly to carry the transmission.
if you want to talk on FM you might want to become a Amateur "Ham" Radio Operator.
1st. use the signal strength meter found in the menu on the sirius streamer and then find the best position for your antenna, also fyi it depends where you are located in the us , i am in ks and my best direction is on the north side of my house. there may be interference from a strong station on an adjacent channel also .if you are using the fm broadcast feature of your streamer just try to use a frequency that doesn't have a signal on the next frequency to the one that you are using.
Attach the wired headsets, because they will act as the FM antenna. Then, go to 'Menu > Entertainment > FM radio'. Once there, go to 'Options > Auto scan > Yes'. You can make it play through the speakerphone too, by going to 'Options > Listen via speaker'. You can also make it keep playing FM radio while you make other things with your phone, by going to 'Options > Play in Background'.
Hope it works for you.
Cheers!
Carlos
If you have made a recent update this may be the reason you may have lost your FM transmission!!
Tom Tom disabled silent FM transmission on these units to comply with the law in certain countries which prohibit these FM transmissions. Later updates configured the units to output lower strength FM transmissions.
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
