Canon PowerShot A520 Digital Camera Logo
Posted on Oct 03, 2009
In the screen see E8
When star tha camera in aprox 2 seconds inmediatly turn off and bifore that in the screen I see E8
1 Related Answer
Anonymous
  • 2985 Answers
  • Posted on May 19, 2007
SOURCE: MY CAMERA WONT TURN ON..!
Its broke Baby Girl, its broke. As it is not new you will not get much joy from Canon - though you could look up their web site and tell the tale to Technical Support. I tell you this because if it is more than year old - nobody is going to mend it. But if its a model that had a problem- they might - just might swap it for another one. You can only ask. PS to get a nice reply-rewrite this story in normal type and grammar Never send messages in capitals -thats kinda like shoutin' and no one likes to be shouted at do they?
tip
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom
Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit Reviews
Other products by Canon Ratting Out of 5.0 Special Offer Total New 1 Total Use 0
Read More From Here Now
Kit includes:
♦ 1) Canon EOS Rebel T2i Digital SLR Camera
♦ 2) Tamron 28-80mm Zoom Lens
♦ 3) Tamron 70-300mm Di LD Macro Zoom Lens
♦ 4) Transcend 16GB SecureDigital (SDHC) Card
♦ 5) Precision Design 1000 Deluxe SLR Pro Carrying Case
♦ 6) Spare LP-E8 High-Capacity Lithium-Ion Battery Pack
♦ 7) Precision Design USB 2.0 SD/SDHC Card Reader
♦ 8) Image Recall Digital Image Recovery Software
♦ 9) Precision Design Memory Card Storage Wallet
♦ 10) Precision Design Deluxe 6-Piece Cleaning Kit
The Canon EOS Rebel T2i features a class-leading 18.0 Megapixel Image Sensor and increased light sensitivity for low light photography, as well as an advanced HD Movie mode for gorgeous Full HD movies. Able to capture up to 3.7 frames per second, it's ready to go the minute it's picked up. Advanced Live View, a new wide-area screen, plus features like Canon's brilliant Auto Lighting Optimizer and Highlight Tone ensure brilliant photos and movies.
This set of Tamron lenses includes a 28-80mm standard zoom lens, and a 70-300mm Di LD macro zoom lens.
Take more high-resolution pictures faster with this 16GB High-Capacity SecureDigital (SDHC) memory card.
Increase your shooting capacity with this powerful LP-E8 Lithium-ion rechargeable battery.
Made from durable nylon, and outfitted with a leather reinforced handle, this multi-compartment case will easily hold your camera, lenses, flash, and accessories.
Transfer files quickly and easily with this convenient USB 2.0 SecureDigital (SD) Card Reader.
Retrieve lost or deleted images from your memory card with Image Recall Digital Image Recovery Software.
Keep multiple memory cards protected and organized with this durable storage wallet.
Technical Details - KIT INCLUDES 10 PRODUCTS -- All Brand New Items with all Manufacturer-supplied Accessories + Full USA Warranties:
- <#1> Canon EOS Rebel T2i Digital SLR Camera PLUS + <#2> Tamron 28-80mm Zoom Lens + <#3> Tamron 70-300mm Di LD Macro Zoom Lens +
- <#4> Transcend 16GB High-Capacity SecureDigital (SDHC) Card + <#5> Precision Design 1000 Deluxe SLR Pro Carrying Case +
- <#6> Spare LP-E8 High-Capacity Lithium-Ion Battery Pack + <#7> Precision Design USB 2.0 High Speed SecureDigital (SD/SDHC) Card Reader + <#8> Image Recall Digital Image Recovery Software +
- <#9> Precision Design Memory Card Storage Wallet + <#10> Precision Design Deluxe 6-Piece Lens & Digital SLR Camera Cleaning Kit
See more technical details
images Product
Read more Canon EOS Rebel T2i Digital SLR Camera + 28-80mm Zoom Lens + 70-300mm Zoom Lens + 16GB Memory Card + LP-E8 Battery + Case + Accessory Kit
on Jul 13, 2010 • Cameras
When I try to turn on my camera, inmediatly it turn off by itself, what can be wrong , and thanks for your help.
Many things could be the cause:
1. bad battery
2. bad shutter
3. bad CCD sensor
4. Bad flash
The thing is to do is take it to a local camera shop and have them look at it. there is no way we can pinpoint it here on fixya specially without further details on the camera.
thanks and please leave ratinga and feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
When a i try to print , inmediatly error lsu loks
Bad laser, and/or possibly a bad laser and power supply.
1helpful
ACCESS???
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
My Olympus FE-170 turns off
keep the camera in the auto on the mode dial
Pink lines only down the middle of the screen aprox. 12" wide for spit second.
Most likely will get worse as you are describing a failing control bd. The part # is 6871QCH038A and is a fairly complicated repair. A good deal of disassembly required, and I would take advantage of your service agreement.
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
