If your Roper oven is not heating, there are several possible causes. Here are some steps you can take to troubleshoot the issue:
Check the power supply: Make sure the oven is properly plugged in and that the circuit breaker hasn't tripped. If the oven is getting power but still not heating, move on to the next step.
Check the heating element: The most common cause of an oven not heating is a faulty heating element. You can test the element with a multimeter to see if it's working properly. If the element is faulty, it will need to be replaced.
Check the temperature sensor: Another possible cause of an oven not heating is a faulty temperature sensor. This sensor regulates the oven temperature, so if it's not working properly, the oven won't heat up. You can test the sensor with a multimeter to see if it's working properly. If the sensor is faulty, it will need to be replaced.
Check the oven control board: The oven control board regulates the oven temperature and controls the heating elements. If the control board is faulty, the oven won't heat up. You can test the control board with a multimeter to see if it's working properly. If the control board is faulty, it will need to be replaced.
Check the oven thermostat: The oven thermostat regulates the temperature in the oven. If it's not working properly, the oven won't heat up. You can test the thermostat with a multimeter to see if it's working properly. If the thermostat is faulty, it will need to be replaced.
If you're not comfortable troubleshooting the issue yourself, it's best to call a professional appliance repair technician to diagnose and fix the problem.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
