Compaq Evo D510 PC Desktop Logo
Posted on Oct 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just added new memory and now nothing comes up when powered up I checked to make sure I had the stick in correctly, but the computer beeps when powered up, and nothing shows up on the monitor...
Anonymous
Level 3:
  • Master 557 Answers
  • Posted on Oct 02, 2009
Anonymous
Master
Level 3:
Answers
557
Questions
Helped
196589
Points
1635
The computer beeps because of a memory problem. Even new parts can be bad or maybe the ram is the wrong type or speed. Take the ram out of the computer. Return it to the origional config. If it starts OK then
you will have confirmed whats wrong. Im sure you know to make sure your grounded while inside the unit. One static spark can destroy the motherboard.
Anonymous
Level 2:
  • Expert 63 Answers
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
13016
Points
175
Try turning the computer on without the new memory stick in. If that works, it's either the new memory stick is not plugged all the way in (most probable), the new memory stick is not compatible with your computer (highly unlikely since I'm sure you checked compatibility first).
Best way to put a mem stick in is to hold it on top and push it firmly downwards until the clips that secures the mem stick click in place. :)
Computer beeps 3 times at power on
Three beeps with no delay tells me bad memory stick or mismatched memory. Check to make sure they are installed correctly. Also if you have more than one stick you can check to see which one is bad by removing them one at a time and then powering it back on it comes on with no beeps you found the bad stick. If it does beep shut it down take out the other stick and replace the first one you took out. Try it again. This will tell you if one or both are bad.
3answers
Hello, i have a dell inspiron 530 and when i turn it on, all you hear is the fan spinning and it doesnt stop. Nothing comes up on the screen and i've checked all the parts and everything seems fine....
Hello-
Welcome to FixYa, the world's largest product support community.
Most of the time if a Desktop computer turns on but you see nothing on the screen,
It may be an issue w/ the monitor or it's cable connection.
Please verify that the monitor cable is connected to the correct port. By default the Dell™ Inspiron™ 530 only comes w/ a VGA monitor port (built-in graphics adapter) at the back unless you installed a discrete graphics adapter on the computer.
If the monitor is connected to the correct port then you might consider running a monitor Power-on Self Test (P.O.S.T).
How to do a Monitor Power-on Self Test (P.O.S.T)
1. Unplug the monitor's data cable, this is the cable that goes to the back of your computer tower.
If you are using an old monitor most likely you have a VGA monitor. Unplug the VGA cable.
2. Make sure the monitor's power cable is plugged in.
3. Turn the computer on.
Fig. 1. Sample Monitor Power-On Self Test.
Fig. 2. Sample Monitor Power-On Self Test.
If these troubleshooting steps doesn't help. Please reply to this post as we may need to go through more troubleshooting steps.
Regards,
Deathschythe
4helpful
4answers
On power up it beeps 3 to 4 times and won't boot up
If there is no display coming on your screen check your computer RAM here is the beep codes for your dell computer i hope this will work for you
Regards
manish
1helpful
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Emachine model #3410 when I try to turn it on it just beeps but nothing comes on the monitor won't even come on. What can I do?
Sounds like a memory error, try this:
With the PC unplugged remove any new memory you have installed then plug it back in a power on.
If you haven't added any new memory than you have a bad memory module. If there are two sticks remove one at a time and check to see if the system starts up(unplug pc before removing ram.) If it starts up than that is your problem. You can purchase new ram relatively cheap.
3helpful
2answers
Computer does not boot up
Computer has three short beeps as it starts? computer RAM (memory) related issue.
Hope this helps.
1helpful
2answers
Hi, i have an acer aspire 1640z i upgrade my bios from 3a18 to 3a24. after installing my notebook restart and i hear 3 beeps ( 1 long, 2 short) and my lcd doesn't turn on the motherbord work fine. Please...
1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
  1. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  2. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
The RAM is located under the laptop behind a hidden panel.
Good luck and let me know how you get on and if you need any more help or advice.
2answers
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
1helpful
3answers
Added a memory stick to my Dell 2400 Desktop computer and the monitor, mouse, & keyboard won't work
Hi
The supported Memory types for Dimension 2400 Series is PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC). Supported Memory capacities are 128, 256, or 512MB and a Max if 1GB (1024MB).
The first obvious question is does the new 512MB Memory module meet the above specification? Some Memory modules are able to steep down speed.
If it does, then first ensure the new memory module is properly installed. Take ESD (ElectroStatic Discharge) precautions or you may damage the new memory module and/or the system board.
To proceed compare the system beeps and diagnostics lights color and sequence to the Advanced Troubleshooting guide.
It is possible that the new memory is DOA (Dead On Arrival). Or there is a new fault on the system. If you have access to another compatible system, you may test the new and old memory modules. You may also swap the new and old memory modules to determine if the memory slot is at fault.
Lastly, if you remove the new memory module, does the system complete POST (Power On Self Test)?. If it does you may indeed have a DOA or incompatible part.
Mike
Computer turns on and beeps.
I suggest you check you memory sticks, and make sure they are seated properly. The long beep usually signifies a memory problem. If you have 2 memory sticks, I suggest removing 1 of them, then tuen on the PC, if it still beeps, powerdown by holding the power button in until it shuts down, then replace the removed one, and remove the other, if it boots, fine, then you will need to replace the memory that you have removed, but,,,,,if you only have 1 memory stick, I suggest you replace it, if the pc still beeps a long beep, then 1 of the memory sockets is bad, and a motherboard replacement is needed, either case, that long beep is a memory problem.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
