Keyboard is stuck in numeric mode. Can't type letters with out using the function key
Depending on your laptop model it will vary on how to disable the fn function. First check if you numlock is on, if yes switch it off. Second check if your bios setting numlock is set to on, switch it off.
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
SOURCE: Panasonic Toughbook CF-51 laptop blue FN key locked on
Hit "FN" and the "NUM Lock" key together to unlock it.
I believe thats the combination.
Let me know.
SOURCE: function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
SOURCE: The function key is stuck on my Dell laptop
Just press the funtion key and the Numberlock key
FN + NmLk (Usually on the same key as delete)
Please rate this a fixya
