ViewSonic VX910 19" LCD Monitor Logo
Posted on Oct 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need more volume on computer speakers - ViewSonic VX910 19" LCD Monitor
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Oct 02, 2009
Anonymous
Expert
Level 2:
Answers
55
Questions
Helped
14837
Points
110
Buy yourself some stand alone speakers, a base & two side speakers, they cheap these days, base speaker has buit in amplifier & plugs into mains, or get surround sound 5speakers & a base, again mains powered, loud enough to annoy neighbours on full. Built in monitor speakers are renowned feeble tinny sounds. Right click speaker icon, bottom right, on your desktop toolbar, open volume control, ensure volume sliders set to max.
3answers
How do I make the volume from my speakers louder than my computer speakers?
depending on the auxiliary speakers you have, there needs to be a power source (either batteries, a power supply, or an ac cord); and the power needs to be turned on. Symptom sounds like you don't have the external power connected or turned on.
How to increase speaker volume on my laptop
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
hop this helps
Computer detects speakers but no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
No sound
if you dont have the sound drivers on a disk you will need to download them
also
I have no volume
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
2answers
I can use headset but my pc has no external sound
TRY CONNECT THAT SPEAKER TO OTHER COMPUTER FIRST. THEN ALSO CHECK-UP POWER ON LED , VOLUME CONTROL AND AC PLUG.
Hi my computer speaker volume is very low how can i set it
If you have put you volume on the speakers to full and there is no change go to start-control panel-Sound-speakers and then you will see your volume control, just put it up as high as you need ;-)
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Volume control unresponsive
The LED didn't turn on ,indicate the DC pwr was missing , you need to ensure there is a Dc supply to the speaker unit,once you got the LED on you will be able to control the volum.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
