Here is a color diagram of the distributor plug for a 1997 Nissan Sentra GA16DE:
Pin 1: Black/White wire - Ignition pulse signal Pin 2: Green/Red wire - Ignition coil power Pin 3: Black/Yellow wire - Ground Pin 4: Blue/Yellow wire - Engine speed sensor signal Pin 5: Yellow wire - Power supply Pin 6: Green/White wire - Ignition coil signal Pin 7: Red wire - Power supply
Please note that wire colors may vary depending on the specific vehicle and wiring harness. It's always recommended to double-check with a wiring diagram or a professional mechanic before making any electrical connections.
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black Car Radio Accessory Switched 12v+ Wire: Blue/Yellow Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Green/White Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: Yellow Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Red/White Left Front Speaker Negative Wire (-): Red/Blue Right Front Speaker Positive Wire (+): Red Right Front Speaker Negative Wire (-): Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Blue Left Rear Speaker Negative Wire (-): Yellow/Red Right Rear Speaker Positive Wire (+): Light Green Right Rear Speaker Negative Wire (-): Yellow/Green
I couldn't find a manual or wiring diagram for this model, but I am fairly sure this is it:
Yellow - Constant +12v (for memory retention) Red - +12v Switched (ACC) Black - Ground Blue
- Power Antenna Orange - Illumination Green - Left Speaker White - Left Speaker Purple - Right Speaker
Gray - Right Speaker
CIRCUIT CARD- -Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order) -Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR. -potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL -Black wire from switch to terminal marked L1 BLACK -White wire from power cord goes to terminal marked N White -Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER- -White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above. -Black wire from power cord goes to swtich terminal marked 4B
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
yellow battery red accessory black ground purple right rear + speaker purple/black right rear - green left rear + green/black left rear - white fr left + white/black fr left - grey fr right + grey/black fr right - blue auto antenna blue/white rem amp brown phone mute orange/white illumination grass green handbrake but if u want to play dvd's whilst u drive connect this to earth
thats the radio here's the diagram for your car 1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
1. you can go here and get a wiring manual with right model #. http://www.alpine-usa.com/US-en/support/
2. The red wire goes to ignition switch/key.
Yellow wire goes to constant hot/battery.
Black wire is ground.
Blue wire is for power antana you do not need to hook that to anything.
You can look at this diagram for a little more help it is not your radio though but it will give you a reference point to look at. All radio red,yellow,blue,black wires are the same on all radios. http://vault.alpine-usa.com/products/documents/OM_CDA-9884.PDF
go to page 42 on this site for wire diagram.
Good luck with problem.
