Recoton Advent Advent DV1418A 14 in. TV/DVD Combo Logo
Posted on Dec 20, 2007
Advent 27 inch flat screen
27 inch flat screen advent i hit a button on the remote with another remote and it locked it. I never set it and cant find the book help me please
  • dbenaharon Nov 28, 2008
    DV2020A model, my kid hit a button and now it has a picture of a red lock on the bottom of the screen on the left side, no buttons on the tv works and on the remote all I can do is turn on and off the television
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
302
Points
I have model dv2020a television and it is locked. i cant unlock my television. i don't have the remote i have a universal remote can u help me.
I have an RCA tv that the parental locks are set on and now the remote wont turn the tv on
you probably need to go for a universal remote , and check as the problem might be on the existing remote may not be working and then using the universal remote , u can undo the changes you have done .
When i got cable i hit the menu button on tv and locked it and ever since then i cant turn tv on how would i fix that? i am trying to program a remote for it but i cant without it being on. is there away...
hi there !
there's a default settings in your remote try to reset the remote , or maybe you just forgot to read the operating manual before using it. from there you'll find the answer with the remote problem.
Be patient. Thank You
Apex tv model gt2711s blue screen with a lock icon at bottom left of screen. Tried solutions mentioned. Cant get to menu. I bought a replacement remote Model RCU-200 Turns the set on and off. Locks and...
Hello
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK
Happy New Year
We cant get rid of the input signal off of the t.v screen ??
Hi I had this same problem. And after hitting every button I learned that on the remote there is a button that says display you simply hit that and it removes it off the screen.
25helpful
3answers
Fpa lock on my rca tru flat tv
here is my solution. somebody either needs to give me a solution without a remote or fuckin mail me a remote. and if i ever run into these RCA dipshits, ima beat some ***** *** for puttin the damn lock on there in the first place.
signed,
Jay and Silent Bob
Advent tv/dvd 27 inch flat screen. Weird Cable and power and volume problem
I have read that if you unplug the unit for more than about 4 hours, it will reset to the factory settings, and that wont be a problem.
this is at:
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7770,1
I quote one guys fix below:
JazzyDaveNew Member Joined: November 2008 Posts: 1 View Profile
The factury remote that came with my 20" Advent lost many of it's functions. I recently purchased the Phillips Remote SRU4105WM/17 and it works perfectly with the Advent as well as my other equioment. Buy has it fo $8: http://www.buy.com/retail/product.asp?sku=208673201
3answers
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
2answers
15 DAY OLD TV
Make sure you are hitting the right menu button. Samsung thinks they are dummy proofing their tvs. You cant get to anything they do not think is pertinent at the time. Make sure you are hitting the write button on the remote. Try to hit menu on the tv and see if that works.
10helpful
8answers
27" MAGNAVOX W/ CHILD LOCK ON- NO REMOTE!
On those particular Magnavox TV's you have to use the original type of remote to power it back on then un-lock the parental lock. It is a bummer that nothing else will work. Here is a link to purchase a replacement remote.. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod
Top Recoton Advent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
