Why won't the elements come on?
SOURCE: all elements cease to work after self clean
If the electronic control is blank then an inline fuse to the control has blown due to overheating in the area of the controls. If the controls are visable but nothing in the way of high voltage works then that is the limits in the rear of the ovens.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: self-clean not cleaning
I was wrong (I think). the baking element probably was burnt out as the repairman said. He replaced it and I thought selfclean still wasn't working. In fact, I think I just had to give the self-clean function more time. Also, I was judging by smell. We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair. Bottom line, the oven was clean after the baking element was replaced, sans smell.
SOURCE: I recently put my oven through the self clean
Probably the Thermal Overload Sensor burned out from the excessive heat during the cleaning cycle. It Is located on back side of oven.
SOURCE: The power won't come on
Hello, Thank You for using FixYa. I will be helping you today.It blew the thermal fuses one on the back and one on the control replace both even if its just one.The one on the back top oven is part 9759243 and the control one is 4456654. For the back one you have to pull the oven out and the control one remove the front side rails then the control side screws to open the control
Thank You and please rate my answer if it was helpful..
SOURCE: oven door won t open after self clean cycle
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The
problem normally is that the user has interrupted the clean cycle and
the door is locked by default or the door lock assy has failed all
together .
Now here is the thing these ovens have a built in memory
module that stores a number of commands that the user has input in it
like self clean or broil ect.ect so what you will have to do is to
clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now
only after the hour is up plug in the oven and you may hear a beep ora
click if so great wait a few min then you can press the cancel button
then try to open the door again.
Now if this has not worked then you
will have to remove the top part of the oven to get to the latch asy
which means you may have to remove part of the back of the oven or the
entire back piece depending on your model to be able to remove the
screws that hold in the top of the oven on the back then you should be
able to see the latch mechanism
Now remove it and have it tested or simply replace it ok
Hope
this helps please keep me informed on how this is going i can send
you a link to a site that has a video on how this is done if needed ok
to help you repair this
Best regards Mike
