Garden Logo
Posted on Oct 01, 2009
Need head for older homelite trimmer. ut 200. what do I buy? want line already on head. is a curved shaft (gas) and at least three years old if not more.
Anonymous
Level 1:
  • Contributor 17 Answers
  • Posted on Oct 01, 2009
Anonymous
Contributor
Level 1:
Answers
17
Questions
0
Helped
18194
Points
68
If you are talking about a ST 200, ( I don't think there's a UT 200 trimmer, "ST" means "String Trimmer") heres the head you can buy:
http://www.odonnellsautoparts.com/servlet/the-16894/Mini-Bump-Feed-Trimmer/Detail
1helpful
I was given an electric start Homelite line trimmer, Touchstart UT-20683. Its like new condition but mising the wall charger. I need to know the voltage requred to charge the battery. Does anyone have
Funny I picked up one today...for $20. It too is missing the wall charger...it I find one I'll let you the source, meanwhile the voltage is 6. Hope this helps. I'll keep you posted Re: the charger..
Jun 22, 2012 • Garden
Need to know the spark plug gap for Homelite 25cc Model UT-20779
The spark plug gap should be set at .025 to .030 inches for trimmers. Try to set gap closer to .025.
3answers
I need a new trimmer head for myhomelite trimmer model HTL800A
I see that this is an older model electric trimmer. The correct model number is HLT800A. Parts for electric models are difficult to find (online). Most service centers refuse to work on them and they say it is not cost effective. They basically just issue warranty replacements. Even Searsparts direct that has parts for most makes and models only lists gas models for Homelite.So, if you can get the old head off (or even if not); take it to the Home Depot garden center and there you will find a vast array of different string heads that may or may not fit this model. I know that most of them are for the gas machines. You may even find a new electric model on sale there that suits your fancy. I have been unable to find any spare parts listed for this model.
Need a manual for Homelite weed eater, UT 20760. It can be in PDF format. Forward to [email protected]. Thanks
You can download the trimmer PDF for free here - http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_trimmer_product_list.html
2answers
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
1helpful
Need part number s for the entire head assembly of the Homelite Trimlite UT20721" or manual and diagram
Hello daniel_s_kmi:
If I Understand you, you are Looking for the Part Number for the Complete String Head.
If this is Correct, then the Part Number is DA3001A.
>>You can View a Breakdown of this Unit at this Site Addy; http://www.homelite.com/service_support and Select Order Parts. Now Select "Click to Launch Homelite Catalog". Now Enter the Model Numbers (UT-20721) and Click Search. Now Double Click on the Model in the Results Area. Now you can View the Breakdowns for this Unit. Select the "Shaft-Spool and String-Grass Deflector" File. The Complete String Head is # 17 in the Breakdown.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
4helpful
3answers
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
2helpful
I need a manual for a Homelite Mightylite 17 inch Curved Gas Trimmer with EZ wind Bump Feed UT 21907 Ser #642287
Go to homelite.com then click on service and support, then click order parts then click launch homelite parts catalog, Agree to terms then click continue under model no type in mightylite then find you trimmer in list.
10helpful
4answers
Homelite zip start 2cycle trimmer.
I had this same problem, would run a couple of seconds, stop, and you couldn't start it again.
Had good gas/oil mix 50:1 and 25cc Homelite. Had replaced the fuel filter, gas, spark plug, and took carb apart and cleaned with carb cleaner and primer bulb worked fine. None of that fixed it. What did? Take the muffler off and see if it will start and run with the muffler off. If it does, chances are the muffler is clogged. Also check the exhaust ports and clean them out if plugged with black oil carbon residue.
My muffler was clogged up, took it off, cleaned out the exhaust ports, there was some oil that was in the muffler(oil that didn't burn during combustion). It now starts and runs like a champ on first or second pull.
Top Garden Experts
Jay Finke
Jay Finke
john h
