Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." CRAFTSMAN 934 205111 Operator Manual commin problem with wire feed welder Wire won stop feeding
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
