Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
In lexmark e260dn when i connected to lan it is not getting ip
Note: If you do not know the IP address of the printer, then print a network setup page and locate the IP address
Click Reports.
The following reports may be viewed from the Embedded Web Server:
Reports
Device Statistics
Device Settings
Device Information
Profiles List
Printer Server Setup Page
You can solve this through any computer that can print to the printer.
1. Press Settings on the Control Panel
2. Use the arrow keys on the printer to select " Network Settings" and press the check mark key
3. Use the arrow keys on the printer to select " TCP/IP" and press the check mark key
4. Use the arrow keys on the printer to select " View IP Address" and press the check mark key
5. Write down the IP number displayed on the LCD (i.e. 192.168.1.205)
6. Enter this number in the address bar on computer (i.e. http:/192.168.1.205) and press enter
7. The Lexmark Printer Status page should display
8. Select "Configuration" and "Scan to Network Host Management"
Now you can delete any computer name that is no longer needed.
