My condenser fan starts with either compressor as it should but does not seem to shut off very often. (I have cleaned the condenser with compressed air and confirmed it is very clean.) What signal or setpoint actually shuts the fan off? Does the control board look for a specific temperature, pressure, or just have an off delay timer?
The Defrost timer turns it on and off
I’m happy to help further over the phone at https://www.6ya.com/expert/george_106a9535a98aec8a
Your condenser fan motor should run any time the unit is calling for cooling, if the compressor is running, the condenser fan should also be running.
Hope this helps....GOD BLESS....Randy....
SOURCE: Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
[email protected]
SOURCE: sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
SOURCE: GE Fridge intermittent
I had the exact problem with my GSL25JFRFBS. It turned out to be a bad control board. The service technician that replaced the board said that the lights dimming on the on the ice/water dispenser is a direct indication of the control board being bad. This cost me $303.53 and my refridgerator is only a little over 2 years old. You can buy a new control board - WR55X10656 from GE online for a little over $157.00. From what I've found, this is an inherit issue with this model.
SOURCE: Fan / Compressor runs constantly
Condenser fans (the fan next to the compressor) do run all of the time. That is normal.
SOURCE: My Danby DWC512BL has stopped cooling. The
Replace that fan
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
