I wish to change one extension from the current line pool to another. Can someone advise?? I am operating the Norstar Meridian M7310 and have administrative logins.
Programming is done on 7310, 7324 and 7316 type sets.Enter programmiChange extension to another line pool - 2.gifg src="/uploads/images/2.gif" alt="2.gif" class="h_mi" /> by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the pool on.
Press the show key (top right arrow)
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key till you get to the desired pool(bottom right arrow) .
Press the Chng soft key from N to Y
Press the heading key till the display says Line Pool Access(top left arrow).
The display should say Prime Line
Press the Chng soft key till you get to the desired pool
Press the release key when finished
Ok,yours is the older template for programming,sorry.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
the display says A. Configuration
the display will say 1.Trk/Line data
the display will say 2. Line Access
Enter in the extension # you wish program
the display will say Line Assignment
Press the next key3 times(bottom right arrow) .
The display should say Line pool Access.
Press the show key (top right arrow)till you display the line pool you want to program access to
Press the chng key. change from N to Y.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Hi, thanks for this response! However my screen does not read TERMINALS&SETS. On login it gives me options A. Config, B.Gen Admin, C. Extn Copy, D. Maintenance and E. oftware. In the menus of each of these I cannot locate TERMINAL& SETS either.
Can you advise???
