Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No freeview channels only channels 1,2,3,4,5.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Oct 01, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737371
Points
36074
Go to menu and look for "autoprogramming" and it will scan all available channels.
LOGIK L1HSTB12 Freeview+ HD Recorder. - using on a network.
Here is your manual.
https://currys-ssl.cdn.dixons.com/manuals/LOGIK%201TB%20Freeview%20HD%20TV%20Recorder%20L1HSTB12%20Manual.pdf
With the BBC Content you need to sign in with your account. You must also make sure you aren't using VPN and have a UK based IP Address.
TV Guide
Freeview https://www.freeview.co.uk > tv-guide
The biggest shows live and on demand all for free with Freeview Play. find out more · BBC ONE Lon. Series 23: 40. Devon and Dorset. Escape to the Country · BBC ...
Freeview
TVGuide https://www.tvguide.co.uk > mobile
TV Guide for all UK channels including Sky, Freeview, Virgin and Netflix. See what's on TV now and next and search for your favourite shows.
Freeview Channel Guide
tvchannelguide.co.uk https://www.tvchannelguide.co.uk > freeview
Freeview Channel Guide · 1 - BBC One · 2 - BBC Two · 3 - ITV · 4 - Channel 4 · 5 - Channel 5 · 6 - ITV2 · 7 - Regional TV · 8 - Regional TV
TV Guide & Listings
Radio Times https://www.radiotimes.com > tv-listings
TV Guide and Listings for all UK TV channels; BBC, ITV, Channel 4, Freeview, Sky, Virgin Media and more. Find out what's on TV tonight here.
Hi my Son has upgraded his old tv in bedroom to a Bush smart tv model no DLED32287HDCNTDFVP. I installed the channels first time. I have freeview channels except I cannot get the Sky channel to show?
When you say you have freeview channels, and then say you cannot get Sky channels this is not enough information that you have provided, but
I presuming in addition to freeview channels you also have a Sky Satalite receiver which is no longer connected to your Tv or your sons tv Either way Sky satalite have 2/4 lines which means you can have four viewings providing multi rooms is bought from sky, and additional boxes are fitted.
Or you can have 1 sky box main Tv and no the spare cable feed at the back of the sky box you can feed another cable to another tv from that same box but it will be same channels But you can now change channels using magic eye receivers etc, in any room.
But the question I believe is you had freeview but no long can receive sky channels the information is a little vague but hopefully I have helped a little
I can get channels 1 to 4 can't get channel 5 and no freeview
Hi, I had the same problem, try removing your aerial from the box - retuning and saving so it blanks out all previous channels and then reattaching the aerial and doing another retune, this worked for me. Good luck.....
6helpful
2answers
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
1helpful
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
