THE TV TURNS ON FINE AND HAS GOOD AUDIO BUT PICTURE WILL DISAPEAR IN A FEW MINUTES TO A ALL GRAY PICTURETHE TV TURNS ON FINE AND HAS GOOD AUDIO BUT PICTURE WILL DISAPEAR IN A FEW MINUTES TO A ALL GRAY PICTURE
You can't post conmments that contain an email address.
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
Hold down the Menu and Menu up/scroll (+) buttons simultaneously on the Apple Remote for 6 seconds.
TV will cycle through all of the available resolutions, displaying each for about 15 seconds. Please wait, as it may take up to 2 minutes before a compatible resolution is found. If the display is incorrect or doesn't show up, keep waiting while TV continues to try and find a compatible resolution.
When a picture appears on the screen, navigate to OK with the remote and press the Select/Play/Pause button.
If you think you selected the wrong resolution, repeat these steps again. TV works much better in HD resolutions such as 720p or 1080i. You should choose the 'best' resolution your TV supports.
If HDMI or DVI connections are available on your TV, you can use them instead of component video to avoid this process
That will be a lot of work since you will have to open up the TV and get access to the DVD drive assembly, then you will have to disassemble the DVD drive to find out where the problem is.
This is the reason I will never own TV with built-in DVD, you will not have the TV while the whole TV is being repair due to fail DVD drive.
The repair can be from $150 and up plus parts.
You will be better off buying an external DVD player.
in this case i have to know if your tuner is working fine or not.
First of all i like you to connect any external player Exp. DVD or blue-ray player if that works with audio then it is inverter board. if audio doesn't work then its main board.
Also you will find out that if dvd is working fine on your tv than your tv setting is wrong or the tunes is dead. either way if tuner is gone then you have to change the main board.
Either way let me know what went wrong i can provide you more information about what part need and where can you get it from.
Please let me know if you have any further questions or concerns.
Also rate me if you like this post.
Thanks.
It sounds like your main board whent out on you, one thing you can try before you pump any money in to the set is contact a westinghouse tech at [email protected] about the issue (model#, seria#, and TW#) all located on the back of the unit, you might be able to fix this with a Firma Ware update. There is also a few tricks to make the DVD's come out of the drive when they are stuck. Hope this information is helpfull and you get this problem fixed A.S.A.P. good luck.
You need a T-con Board and I have that one for $80.00.
I reclaim working components for TV damaged in shipping or returned for
other reasons. Simple repair for any body with a Philips screwdriver.
NO special tools needed. [email protected]
