I have a sachs dolmar about 15 years old. it uses about 2 tanks of oil to 1 tank of gas and if you hold it above a log and squeeze the trigger you can see oil flying everywhere. I just need to know how to adjust the automatic oiler.
On my Pioneer it is under a cap screw. HTH
Lou You might also try here: ArboristSite.com Chainsaw thread (free to join) http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of professionals, amateurs, mechanics, and whole bunch of nuts. At least member has a rotary engine Sachs Dolmar.
I should have inquired, are you using bar oil? That is really excessive if it is. Bar oil is thicker and stickier than most oils. I get mine at Ace Hardware.I should have inquired, are you using bar oil? That is really excessive if it is. Bar oil is thicker and stickier than most oils. I get mine at Ace Hardware.
You can't post conmments that contain an email address.
The best way to adjust the oil flow is by thickening up the chain and bar oil with some 80 or 90 weight oil. this will take a bit of experimenting due to the temperature and other factors.
Take the bar and chain off and clean both thourghly. Use a small blade screwdriver to scrape built up saw dust,dirt woodchips or whatever from bar track and make sure both are in good shape. The oil port should be located by bar alignment pin.Brush it clean and if you have access to compressed air then blow out to help clear port. Turn your saw upside down and locate screw that has directional arrow to + or - to add or subtract amount of oil flow.
I would start and run saw with bar and chain installed and properly tensioned. Let saw warm up then hold saw about one inch above clean piece of wood and run at full throttle for 30 seconds.There should be a light coating of oil on board. If you have too much oil then turn screw in direction on - until you get it set where you want it. There should be a light coating of oil on chain and bar at all times.
I mostly use stihl saws and run about 1 1/2 tanks of gas per tank of oil and this works great for me. Hope this helps you. Thanks.
Oil Mix Ratio: The following ratios have been recommended for the last 10-15 years. Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1. • 1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil. • 4 liters of premium fuel to 80 milliliters of quality 2-cycle oil. McCulloch, Poulan & Wen; recommend 40:1. • 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil. • 4 liters of premium fuel to 100 milliliters of quality 2-cycle oil. Chinese chainsaws recommend 25:1. If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck. Lou Thank You for using FixYa.
"Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more." The above excerpt is from the Echo FAQs (6) here: http://www.echo-usa.com/faqs/
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
