My oven won't reach temperature all the time. it comes on but it only gets to about 250 degrees. I think the thermostat may not be working correctly but don't know how to check or repair
Re: my oven won't reach temperature all the time. it
It is adjustable. Pull off the temperature knob behind it you will find the adjustment to raise or lower the temp. You will need an oven thermometer to test after you adjust.
The temperature for the TCO in your fan oven should be set to the desired cooking temperature for your recipe. This will depend on the type of food you are cooking and the recipe you are following.
For example, if you are baking bread, a typical temperature would be between 350-450 degrees Fahrenheit. If you are roasting a chicken, a common temperature is 375-400 degrees Fahrenheit. If you are cooking a casserole, a good starting point is 350 degrees Fahrenheit.
It's important to follow the recipe or guidelines for the specific type of food you are cooking, as the correct temperature and cooking time will vary based on the ingredients and method
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
