Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gear selector I have a craftsman 6 speed transaxle lawn tractor model 917.272070. It will not engage any gears. It is as it the gear selector has beome disconnected, and/or the brake/clutch peddle is depressed. I checked to see if any thing is loose, but everything appears connected.
mickey813
Level 3:
  • Master 472 Answers
  • Posted on Sep 30, 2009
mickey813
Master
Level 3:
Answers
472
Questions
0
Helped
215125
Points
1078
SOUNDS LIKE THE BELT HAS CAME OFF OR THE PULLEY HAS BROKE
I HAVE A T1200 WITH KOHLER ENGINE. / ON ALL THE LOWER GEARS THE TRANSMISSION? GIVES ME A DONKEY RIDE ! AS IF THEIR IS PLAY IN THE TRANSMISSION: IS IT THE TRANSAXLE THAT IS WORN ?
POSTED TO CARS/TRUCKS
MOVED YAH TO
WILD GUESS ME,
The Craftsman T1200 two-wheel drive lawn tractor was manufactured by MTD built from 2015 to 2020. The components of Craftsman T1200 powerline system: 25.6 cubic inches (420 cc) Zongshen 4P90HU 4-cycle single cylinder 2-valve vertical shaft air-cooled gasoline engine and mechanical CVT transmission with infinite forward and reverse gears. The engine has a float carburetor, splash lubrication system, and electronic ignition system. The maximum travel speed (forward/reverse): 5.5 mph (8.8 km/h) and 2.3 mph (3.7 km/h).
2helpful
Gear shift lever is loose and mower will not move. this is on a craftsman lt1000.
Trace back the linkage from the shift lever to the transaxle to see if the linkage has come apart. If it is a manual, then I know the linkage connects to the transaxle on the top, forward, left of center. There is a retaining bolt (i think bolt, been a long time) that attaches the linkage to the transaxle. If this has backed out very much the linkage is not going to shift gears on the transaxle.
I hope this helps.
10helpful
2answers
Craftsman 42 '' 19.5hp lawn tractor gear shift will not engage. Engine and blades work fine but cannot put tractor in gear.
the belt is bad if not there is trouble in the drive shaft.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Really hard to move gears to reverse or forward
The problem sounds like the transaxle.Thanks for asking and I hope it helps
2answers
My craftsman lawn tractor 42" cut (2007 model) cuts off when i try to engage the cutting blades
You have a safety switch somewhere that is open, like the seat, you have to be in the seat or it will kill the engine, sometimes the clutch has to be in, not moving, sometimes the gear selector in neutral, You have a bunch of safety switches that prevent the mower from spinning if you are not in your seat, not ready, etc. Check them out. Hope this helps.
The mower wont engage in gear
@the rear of the tractor bottom left you'll see a metalrod sticking out and if it hasn't come off a decal with a picture of man pushing tractor that's it.
1helpful
Craftsman riding mower stuck in 3rd gear
you have a broken shifting fork in the transaxle, i know this, i just replaced one on a mower that was stuck in third gear...
2helpful
2answers
Change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
