SOURCE: Scanner component stopped communicating
well, reinstall the software and see if it will work.
SOURCE: hp photosmart 2610
is your operating system Vista.......good luck. my printer worked fine w/XP, scanning and fax functions do not work to date with Vista.
r2d2
SOURCE: Not Printing!!
hmmm..well..this is a fractured driver issue for certain. I have some notes on this in my Tips and Tricks section, you may find of some value.
SOURCE: Automatic Document Feeder
turn it OFF then locate the cable that is connecting the ADF and the main FLATBED scanner. Disconnect and re-connect it.
SOURCE: Can't print documents
I fiddled around with the Owner/Administrator commands and discovered that one of my grandchildren logged on with "different user" and my computer was not set for that user to have access to the printer. Duh!
A quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to scan a document again to
verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
1.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
4.
Reboot your pc.
5.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
