First time I pressed this, a window opened. It had information about burning a disc, how many empty dvd's, etc... But when I slipped empty DVD-R disc in (as instructed) and pressed OK: nothing happened. I tried several times pressing OK, but nothing... Eventually I closed the window and tried again, but I didn't work anymore.
SOURCE: cd dvd writer not working
ok " I would get a dvd/cd cleaner disk, has a tiny brush on it that cleans the lens in your drive.
SOURCE: Restoring to default factory settings
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
2422
SOURCE: Fn F5 not working
Check the BIOS - some laptops can be set in there to start with the LCD, monitor or both.
Hope this helps
SOURCE: Hi, my Acer Aspire 5520G
Enter comfiguration setup and check if secondary IDE device is set to automatically detect drives or replace the DVD drive
Insert a blank CD or DVD into your writable disc drive.
Decide how you want to use the disc:
With a CD/DVD player: Choose this option to create discs that play on CD and DVD players attached to TVs. Don't choose this unless you plan to view the disc on a TV. You can't add any images to this disc later, so be sure to get them all selected the first time.
Type a name for your disc and click Next.
Click the Burn or Burn to Disc button again, if necessary.
Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
Set up Windows Vista with your own personal settings.
