Self-cleaning ovens are not "squeaky clean" after the cleaning cycle has run. Any spilled food or debris in the oven before it cleans will be left behind as ashes, soot, etc. and you will need to wipe it out with a damp cloth afterwards. If the residue is black and sticky then the cleaning cycle isn't running at a high enough temperature. Please refer to the manufacturer's instructions to make sure the cleaning feature is working and being operated properly.
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
They can tell you right on. Great Co.BLODGETT 44 Lakeside Avenue, Burlington, VT USA 05401 Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802)
864-0183
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
Propane burns very dirty,I bet the burner and pilot are clogged with soot.In techinical terms the sound your hearing is blowback.If you check the burner/pilot you will likley see black soot,remove them and clean with soap and water.
Go here find what you seek. BLODGETT 44 Lakeside Avenue, Burlington, VT USA 05401 Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802)
864-0183 Great Co.
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
Go here and find what you seek.They are a great Co. BLODGETT 44 Lakeside Avenue, Burlington, VT USA 05401 Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802)
864-0183
