Timex Expedition E Tide Temp Compass wristwatch Logo
Posted on Oct 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timex exp e tide compas will not work / calibrate
Although i have tried to calibrate many times exactly following the instructions, keeping it level ect, the compas will not consistently point to north. most of the time it will point in a direction and stay there even if you rotate the watch. its only about 6 months old and has not had much wear time! any idea what the problem is or how to fix it?
  • Filip Zindovic
    Filip Zindovic Jan 31, 2019
    Did you solve your problem? Please, help if you did.
TIME TRACK SERVICES
Level 2:
New Friend:
  • Expert 90 Answers
  • Posted on Oct 13, 2017
TIME TRACK SERVICES
Expert
Level 2:
New Friend:
Answers
90
Questions
0
Helped
36017
Points
226
I would advise you to contact timex customer services .
1 Related Answer
Anonymous
  • 714 Answers
  • Posted on Feb 10, 2010
SOURCE: I have a Timex e-tide with compass, temp and tide
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
My time e-tide compass sohws large deviations (>90 degrees) after calibration. I've tried calibration several times, each resulting in slightly different north. The degree of variation per heading...
Low battery can cause this type of fault! Make sure after changing the battery to do the all reset inside of the watch. If this does not work get in contact with Timex for how to have their watch sent for service.
5answers
Timex W-225 -- the tide and temp button are non-responsive
have you try changing the battery...?
or-
did your watch has been been dropped?
How to calibrate timex compass
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
Replace stem on Timex Expedition E-Tide Temp Compass Watch
I am looking for stem and crown for Timex Expedition North Tide Temp Compass watch. Mine broken.
4helpful
How do i calibrate my compass on my e tide watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please..
1helpful
I have a Timex e-tide with compass, temp and tide functions. The compass no longer points north and will randomly point in any direct when activated, is there a way to re-calibrate the compass?
Hope this tip helps
R/
David
2helpful
How to calibrate timex t45601 compass
Hope this tip helps
R/
David
4helpful
Instructions for timex e-tide temp compass watch
Hope this tip helps
R/
David
5helpful
2answers
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
