I think this can be fixed . first reset the router settings and reset the printer also. and now try to setup the connection with advance settings as manual says . for more help contact brother
Printer Tech Support . i hope this will help thanks
SOURCE: I reset my linksys WRT160N router and now the
Power off all of your network devices, including modem, router, and computers. Then power on each device in the following order:
Wait for about 1 minute between each step, do each device has the chance to fully power up. This will reset the connection from your modem to your router and force the router to refresh it's settings. Please let me know if fixed your problem.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: i cant connect my ipod touch to my linksys WRT160N
hi! check first the wireless settings of your router, it may be set only to connect wireless n adpater, u have to set it on all wireless, b,g,n, if the settings is not set to all u will not able to use ur ipod touch to connect, I bliv ipod touch wireless adapter is wireless g. check also the wireless security settings if ssid is not broadcast, make it broadcast or if u dont like to broadcast it, just remember the ssid and try to check as well the wireless settings of ur ipod touch..
SOURCE: Linksys WRT160N Connection Issues.
Sadly, this router has horrible reviews and is known for this problem:
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16833124277
Can you return it for another model?
Can you getLinksys to replace it?
the best one is the LINKSYS WRT54GL, but if you are stuck with the one you have...
If you have tried all these things and you are very brave (or don't care if you need to buy another router) why not try flashing it with an after market O/S?
1) http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
2) http://www.dd-wrt.com/phpBB2/viewtopic.php?t=32576&highlight=wrt160n
SOURCE: how to change network settings on linksys wrt160n
open router page 192.168.1.1 with user name and password admin ,it will allow you to change the settings
