Question about Panasonic NN-T774SF Microwave Oven
Timer problem If I set the timer to cook for say 60 seconds and hit "start", the oven will turn on and the clock will run down to zero in about 5 seconds and shut off. The oven will not stay on for the required time. Any suggestions?
  • 833 Answers
Sounds like your timer board is fried. Replace it.
Posted on Dec 19, 2007
6ya staff
SOURCE:
Hi how do I set a hisense microwave clock,its been giving me a hard time to set it,please help
I know there is a cook timer and a clock ....Hit clock ...set time..then hit clock again....That's how mine works... Hope that helps
Aug 14, 2017 | Microwave Ovens
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Panasonic NN-T774SF Microwave Oven Logo
252 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
