Question about Nokia 6110 Cellular Phone
Nokia 6110 navigator imei : 357666019312898
I need the master code ?
is that unlock code is right #pw+(mastercode)+1#
    New Friend:
I need my security code or my restore factory setting code this is my IMEI:135790246811220...... i just buy my phone 2nd hand so i need the password....for Nokia 6110 navigator
Posted on Feb 24, 2010
Anonymous
SOURCE:
What is the restriction code for nokia x2-02
The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
(I can NOT give you the master code - SO DON'T ASK ME FOR IT !!!!!!!)
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Please NOTE that these codes could be used with care! A user told me that it's only possible to type in about 5 different codes on each lock! Then something bad will happen ..therefore be careful
Jun 03, 2013 | Cell Phones
Sir plzzzzzzzzz unlock phone imei
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For your imei no. the master security code is :
6357407066
May 17, 2010 | T-Mobile Nokia 2610 Pay-As-You-Go Cell...
Hi I am after a network unlock code for my Nokia 6110 Navigator my imei code is 357666/01/214599/8
Visit http://www.unlock-free.com/nokia/
or
http://www.unlock-free.com/nokia-master/
And follow the site instructions.
Rate this please.
Dec 11, 2009 | Nokia 6110 Cellular Phone
Unlock my nokia 6300
Hai,
You can visit the site mobileunlocker.In that site contains the unlocking instructions and unlock code for the nokia 6300.its contains the unlocking instructions for all mobiles.
Jan 26, 2009 | Nokia 6300 Cellular Phone
Security code for Nokia 2100
The main code used in Nokia phones is :
# = DOUBLE-CROSS
Y = NUMBER 1 TO 4
#pw+1234567890+1#
Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx
1. Insert SIM card of different provider.
2. Turn on the phone and press the UP VOLUME key for 3 sec.
Then release it and the phone says PIN CODE?
3. Press the "C" key.
4. Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again.
NOTE: On version 5.04 Nokia has removed this option !
Dec 17, 2008 | Nokia 2100 Cellular Phone
Forgotten security code
The default security code for Nokia is 12345
IMEI: 354827021320559
Master code: 3315741650
Close all applications on your phone.
With your phone switched ON, remove the battery.
Then remove the SIM card.
Replace the battery without the SIM card and switch your phone on.
Type in the security codes (any code) until the phone request the Master code, (in the phone lock window) when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
This is the code needed to reset the Security code, nothing else, and it’s for your phone only.
If it does not request the Master code, your phone will have to be connected to a computer and an unlock box to restore the Security code.
Oct 25, 2008 | Nokia 6233 Cellular Phone
Nokia 6110 unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, LucasMok your IMEI: 357666019013793
mastercode:
461072065x
and the other users please let me know your IMIE number for unlock any phone.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
Aug 19, 2008 | Nokia 6110 Cellular Phone
Unlock code
mastercode:
764454375x
and
Hi, ice_ice_icey your IMEI: 354847011964364
mastercode:
647723117x
Nokia 6110 Cellular Phone Logo
629 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
