I'm out of practice because my camera suddenly stopped working 6 months ago, but I don't recall having a problem with blurry pictures when I used the zoom. Sometimes, it takes a few seconds for a pic to come into clear focus. I think the trick is to just keep working with it.
Probably because at the longer end of the zoom range you are getting camera shake. On the wide angle setting shake will not be nearly so noticeable. Use a tripod for long telephoto shots or practise squeezing the shutter release really gently-like the trigger on a gun ;-)
its likely that she may have hit the macro setting only allowing it to focus up close to objects to turn this off all you have to do is find a button that looks like a flower this could be on the arrow pad or in the menu system but it is called the Macro setting and with it turned off hopefully your pictures will be sharp again
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Question :
Why are my pictures out of focus (blurry)?
Answer :
This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
The subject was not within the effective range of the flash. Each camera has an effective flash range.
The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
you could try putting the setting on Macro and that is the little flower
on the bottom along with the other buttons. then you'll have a nice
clear picture, just don't hold it tooo close to the item you are taking
a picture of.
Kat [email protected]
it could be a few things like dust on your lens when you took an auto picture and it could have blown off from movement make sure your lens is clean, check your lens settings on the side if it is on the flower its for close up pictures and if its on the trees its for further away pictures so make sure its on the correct setting also pc cams only have digital zoom so if you zoom in it may appear to be blurry because it only zooms in on the picture which is made up of pixels as opposed to an optical lens which zooms in on the actual object so its not as blurry also check your menu settings mabey you messed something up, also remember to keep the camera still when taking pictures they are not that advanced. and if non of that works just use manual.
One or more causes may result in unclear (blurry) pictures. Some common causes and suggested solutions are listed below.
The lens is dirty. Clean the lens according to the guidelines for your camera model.
The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera model has recommended distances for normal, telephoto (zoom), wide-angle, and close-up pictures.
The subject was farther than the effective range of the flash. Each camera model has an effective flash range.
The camera did not autofocus or autoexpose the picture correctly. For best Autofocus/Autoexposure function, press the shutter button halfway down and hold. When the AF/AE Indicator (Ready Light on some cameras) turns green, press the shutter button the rest of the way down to take the picture. If the yellow light blinks, release the shutter button. (On some models, the light will also blink yellow if the shutter speed is too slow.)
You did not use the LCD screen Preview feature to take a picture in Close-Up mode. When the camera is in Close-Up mode, always use the Preview feature, both to confirm focus and to aim the camera properly. If you do not do this, the viewfinder will not show you an accurate view of the picture because of parallax error.
The subject or camera moved while you took the picture. Place the camera on a flat, stable surface, and hold the camera very steady. Or use a copy stand or tripod – especially advisable at telephoto or high-zoom settings, or in low light.
