I have an intertherm MGHA-090AAAPQ-01. I cannot get the pilot to light. I took of the pilot line at the control box and there is no gas coming out there. I tried it with every possible valve combination. I have no owners manual for the furnace
There should be a reset button in the upper chamer next to the fan motor. In the middle ,push in on the center red button to reset it, this tripps because it says I,m not gettig enough air flow due to a plugged or dirty fliter located on the front cover or door.
If there are two wires to gas valve check voltage between these two wires while the furnace is going through a start up if you never get a call or voltage to valve your control board is bad, if you are getting voltage ,your valve is bad
dose not light
