Question about RIM BlackBerry Pearl 8100
The battery won't stay charged!
The battery won't stay charged even overnight when it's not being used. I'll charge the battery in the morning and use it all day and won't have any problems then it seems like every night when i'm not using it the battery will completely drain and I'll wake up to a dead phone. I even tried turing the phone off while I slept and it still was dead. How does a battery drain when it's OFF?!?!
6ya staff
SOURCE:
Anonymous
  • 39 Answers
SOURCE: blackberry reset
Check out this link. http://uis.georgetown.edu/hardware/blackberry/bb.trouble.html
Posted on Aug 27, 2007
Anonymous
  • 86 Answers
SOURCE: Battery won't charge in phone.
Have you tried a different charger? If not I would suggest stopping by one of your cellular providers stores and having them plug it in to see if it works.
Posted on Mar 27, 2009
Anonymous
  • 55 Answers
SOURCE: My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Posted on Jun 12, 2009
Anonymous
  • 5 Answers
SOURCE: Blackberry charge symbol appears but does not charge battery
are you using the charger that came with the BlackBerry?  cause sometimes that can make a difference.
otherwise you might just need to get a new charger.
and usually the wall chargers work the best.
i had a BlackBerry Pearl 8100 and the same thing happened to mine.
Posted on Aug 20, 2009
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: Battery Heating Up and Draining Quickly
i think it is a software issue try to reset the phone or update the software of your device if you dont know how let me know i can guide you ,
pls rate me well
Posted on Aug 27, 2009
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
Battery life draining overnight
Try disabling everything you can through the software, if not possible, unplug them. Then plug one in at a time and leave it overnight. If its OK in the morning, plug in the next item, and so on. Make sure battery is fully charged between each test. When the unit discharges overnight again, the last item you reconnected befroe it discharged is the one causing the voltage drain.
Aug 20, 2014 | Toshiba NB520 Netbook
My phone won't charge. What should I do?
Make a soft reset.. By unpluging the battery when the phone is on..
Apr 13, 2017 | HTC EVO 4G Smartphone
Hi it is possible that you Alternator is faulty,if you have access to a VoltMeter ,check the battery voltage in the morning before you try to start it you should have around 12.7 volts for a charged battery if not fully charge your battery again and check the voltage with your car running you should have around 14 volts with the engine reving at 1500 revs.ifyou get around 12 volts then your lights are taking more power from the battery than the Alternator can replace.You could also get your local garage to Drop Test your battery to see if any of the Cells are faulty
Jan 11, 2013 | 1987 Volvo 740
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Truck will not keep and charge over night
The battery won't keep a charge or it won't when it is in the truck? Will the battery keep a charge if you put it on the charger and then unplug it overnight, all of this out of the truck. Then in the morning will it start the truck. If not your battery is bad. If it keeps a charge and will start the truck and then it goes dead after several hours, your truck is drawing a load on the battery. You will have to find what has been left on or shorted out.
Feb 05, 2012 | 2000 Dodge Ram 1500 Truck
My phone charges but never reaches the stage where message says "your battery is full now", even if i leave it overnight to charge. then when i turn the phone on, it's life is only a couple...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 06, 2011 | Nokia 7230 Cell Phone
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
My Motorola Battery Refuses to Charge!!
you may have a damaged battery contact, my suggestion is to get it serviced
May 07, 2008 | Motorola Mobility RAZR V3
RIM BlackBerry  Pearl  8100 Logo
619 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
