That dust is from the carbon brushes on the motor. You may need to check them, and also clean out the motor compartment. A slight noise could be a motor bearing starting to go. Does the smell like rubber or electrical. If rubber, then the belt has stretched and needs to replaced. If electrical, then something is causing the motor to run hot, like a clogged filter, or it could be a motor going bad.
