Take off the gear lever look under it you will see a engine bolt that wen you remove is very close to the gear lever then u know thats the wright one mount the fittings for the stand with the alan key bolts they can be a bit fiddley put the springs on the stand then mount it with the shaft you will have to pull the stand a bit then wen you have it on move the right exhaust clamp round so it doesnt hit the stand.and re fit the gear lever
