The green blinking light will not shut off and the tv wont turn on. do you know whats wrong with the TV?
Here's something that might also be useful. After you turn on the
set, and get the regular red blinky lights, hold down the Device and
Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
We have the blinking green light and the tv will not come on. Please help.
green blinking light wont stop and tv wont turn on
green timer light just blinks (39 days) unit went to shop $800 + - a few $$$$$ emailed mitsubishi no reply(what did i expect).
I have the exact same problem. The manual says to reset the TV, but that didn't help.
Any ideas on where to start to look for fixes?
I have an error code of 1 2. The TV would not work. I pressed the Device and Menu button got the error code. Then tried the power button and the TV turned on. What is error code 1 2
Thanks for the help so far
Error code is 1 2
