My answer is to NOT use that feature, as generally after most people use that :Feature" straight after the oven faults, you see that "Cleaning" mode simply heats the oven up wayyy up to like 900 degrees up, and after this the temperature sensors generally "Go" so my advice is ... use elbow grease and save a lot of possible problems, especially with a 8 - 10 yo unit.
Unfortunately I was unable to find the manual in my database. But still found the solution you can click on these links and refer to the instructions :
Never ever use the self cleaning feature. It is there to make your life a little easier, but it also damages elements, door locks and control boards. The heat is just too aggressive. We see it here VERY often. It is a great way for the appliance makers to earn income in spares. Use the traditional method, spray walls, base and racks in the oven with Easy Off - No Odor Foam, and put a large roasting pan of boiling water in the middle shelf (this prevents the spray drying off). Leave overnight, and wash off in the morning.
12 years old? If it is a gas rnge yo need to get a gas technician out to fix it. I would probably say it s time for a new one. Hers is a couple of things to think of when getting a new stove. 1) Everyone wants a self clean. But 90% never self clean. can save up to $200 w/o that option. 2) 80% off people buy a stovebased on looks. A stove may not be pretty but work just as good as one that is.
I fixed the problem simply by pressing the clean button when the oven was warm, not cold. For some reason not explained in the instruction manual, the oven door safety locked properly and automatically when the oven was warm. I don't know why, but I'll take it!!
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
