Yahoo! Messenger is unable to download files needed for installation. Please check firewall settings and retry installation."
What should I do?
Need some help..
Thanks
Disable your firewall and try again..to to control panel to disable it
The issue lies in the Firewall settings. The Windows Firewall has blocked the Application from connecting to Web Servers. You must have to unblock it to get the problem resolved. If you have a Anti-Virus Firewall, reconfigure it, this will erase the Firewall's rules and will ask again that do you want the application from connecting to internet. You allow it and then it can download.
Thank you Sir,
Have a nice day.
SOURCE: file download problems
This could be a possible that you have set the firewall to block some download and pop-ups on a certain port.
better to re-configure again your firewall settings again to do so..
Anyway if you want a YM exe and not to download it, I have here which you don't have to download the installation, and all you need is to install it and use it.
Let me know here again.
micro~
SOURCE: yahoo messenger is unable to download files needed
Simply close the Firewall for little moment till installing the YM files.Go here Control Panel> Windows Firewall>click Off(not recommended)
Try now. Good Luck
SOURCE: unable to download files needed 4 installation
Go to Start>Control Panel > Add or remove programs remove all the things related yahoo ( Yahoo toolbar, Yahoo mail advisor, Yahoo installer, Yahoo browser plus etc.) Try download and install then....If still same try download offline installer http://download.yimg.com/ycs/msg/dl/msgr10/us/b4/msgr10us.exe
if still you are having difficulty download old version like Yahoo messenger 8 or Yahoo messenger 7
I think it will help you..Further result please let us know... Thanks for being with Fixya...Good Luck
SOURCE: yahoo messenger error
download a latest copy yahoo messenger, sometime when your yahoo messenger become old it cant log you in download from here... this link is standalone installer of yahoo
Click here to Download
install yahoo messenger then log in again
SOURCE: Yahoo messenger is unable to download files needed
Thanks, I checked my IE settings and it was offline due to connection settings. I fixed it accordingly and it was solved. Now I could install yahoo messenger.
