Refrigerator light not on (freezer is) replaced bulb and doesnt feel like it is working. still no light after replacing bulb. Fridge may not be working at all.
removed inner control plate and found insulated connector had come off the terminal for light bulb connectorremoved inner control plate and found insulated connector had come off the terminal for light bulb connector
You can't post conmments that contain an email address.
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Unplug the Whirlpool refrigerator from the electrical outlet. Step 2 Locate the bulb on the inside of the Whirlpool refrigerator. Step 3 Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required). Step 4 Unscrew the old light bulb. Step 5 Screw in the new light bulb. Step 6 Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb. Also note that the below can also work
Unplug refrigerator or disconnect power. Slide the light bulb cover toward the back of the compartment to release it from the light assembly. Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts. Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover. Plug in refrigerator or reconnect power. To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly. The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts. Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly. Plug in refrigerator or reconnect power.
Hi: When you plugged it in how long did it take for the bottom to warm? If it was a week or two it might be your defrost heater(frost builds where it shouldn't). It's just a wire in a glass tube like a light bulb, and will be fragile after years of service. When the freezer works and the fresh food dosn't it means there is no circulation between the two. Frost will build up where you don't see it, and it's where the air channel is between the freezer and the fresh food. When moving a ref. it usually is the def. heater. The light bulb is isolated from this circuit so it may just be the bulb (the filament got shook) or the switch. Good luck Jeff
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
