PTAC Friedrich PTAC PDE12K3SB - no heat I determined that there is sufficient power (220 volts) to the unit ad that the heating coil seems to be good - no burn spots nor break in heating wire - Need reputable service and parts site
How much power is the question. Remember, heating coils usually require 240 volts. You likely are only getting 115 due to a faulty limit switch. 115 will carry through to the other side of the switch from the coil side leading you to believe the switch is good. Remove both sides of switch and test continuity.
Are you getting 120 vac or 220 vac at the unit? Check the voltage at the first terminals inside the unit as well as the breaker. You should have 220 vac at the elements and you are dropping a leg some where.
