Question about Plumbing
I have a house which was built in 1965 and i need to repair the bathroom faucets. the problem is that when i try to repair the faucet i can not remove the little round thing on the front of the faucet handle to get to the screw inside. how can i remove this ?
    Scholar:
  • 43 Answers
Double handle controls, correct? Stamped metal? Thin and can be fragile, but will take some abuse. Okay, take a putty knife, or thin blade flat screwdriver, and place it in the groove that should be about 1/8" inch from the faucet handle top, hold that at about 25 degree angle, and strike the handle of the putty knife or screwdriver lightly. I don't mean a touch like tap, but don't take a mighty swing at it either, Just a little tap, or two, and any corrosion, rust, ect. should let go and the cover should raise a bit. In the alternative, if you can't get them to move or pop off, you can drill through the top of the handle with a 1/2" bit, and reach the phillips screws that hold the handle on that way. replacement knobs are available at Lowes, Home Depot, 84 Lumber, ect. But if the covers are stuck that tightly, then the handles probably are too, I've actually had to use vise grips and destroy the handles to get them off, and then replace them. Just be a bit patient, and they should remove. And if you have to drill them, only drill through the cover plate. About 1/4" should do. Put a peice of masking tape on the drill bit about 1/4" from the end and drill slowly and stop when it goes through. Otherwise you may mess up the phillps head screw that lays underneath. The replacement handles are pretty inexpensive, and if yours are pitted, scarred, rusted, or lost their luster, these will brighten the faucet area nicely. Plan on spending around 6 to 8 dollars for replacement handles. Still, thats cheaper than a faucet replacement.
Posted on Sep 28, 2009
6ya staff
SOURCE:
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
Will replacing a cartridge in my Jado Glance single lever bathroom faucet make the water flow again? It's down to a trickle!
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
Dec 18, 2014 | Jado Plumbing
My delta two handle bathroom faucet the cold water handle is hard to operate tried wd40 on it and it worked for a while but it got hard to operate again
They have a lithium faucet grease for stems at hardware stores Home depot or Lowes. It a gease to help free up for movement of handle if they don't have it try a Plumbing supply house they should sell to public.
May 04, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Moen bathroom wash basin faucet leak, how to repair , we have a new house, 45 days old, bathroom faucet leaks, how do you replace the washer or whatever it takes to stop leak, there are no apparent ways to...
No warrantee on new home?
No instructions left for ALL fixtures,water heater,heating system etc that where installed???
Go to a plumbing supply store,and see if they can help. Not Home Depot
Mar 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
The unit has a croosbar connecting the hot and cold water. How do you remove the crossbar to replace the faucet
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
May 21, 2009 | Delta Faucet 2520 Classic 4'' Centerset...
I have a dipping faucet in my bathroom tub. I
Turn the water off to the residence and then remove the handle. After you remove the handle you can remove the retaining nut. When the retaining nut is removed you expose the internal parts that can be taken to your local hardware store and the parts matched. Usually, there are two small washers with springs up in the manifold that will need to be replaced. You can take your old parts in and usually buy a rebuild kit for it. If you aren't experienced, I would hire a plumber to replace the internal workings. It can be difficult if you cant get the retaining nut off.
Apr 07, 2009 | Delta & Single Handle Shower Faucet
My price pfister bathroom faucet wont shut off.
you may need a new fucet...the manifold opening for the cold has probably craked or split
contct price Pfisterrdirectly they may send you a new faucet
Price Phister is more about looks than function they want to keep their marketing sales
when I built my house I ut rice phister in because of the looks ..function was marginal
Jan 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
191 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
